twocyclemania
- Joined
- Aug 10, 2010
- 505
Before I pull the power head I hope someone will know of an easier solution. The motor overheats. I've been testing it in a barrel. I replaced the pump and impeller. I also removed the head thinking maybe the thermostat was sticking; it had no thermostat. I installed a new thermostat and it's still overheating. Compression is good. I'm thinking the water tube grommet at the head. Anyone else with any other idea before I pull the head and if not how much of a job / any shortcuts in pulling the head? thanks
