15 johnson j15rcsd
realtree280
ok i started tear down and already broke a head bolt any idea what is the best way to remove it , it actually started to turn when the head brok off
ezeke
Re: 15 johnson j15rcsd
If you continue removing the bolts, you may be able to separate the head. <br /><br />Often, the corrosion is in the space below the bolt heads and not in the threads and you may be able to remove the remaining threaded portion with vise grips.
realtree280
you are correct ezeke but i broke the head getting it off now i have to find one of those
