Toronto boater
- Joined
- May 29, 2008
- 20
I posted my stats a few months ago and got some helpful advice. Have a follow up question.
I have a 19.5 foot Sunbird Corsair Cuddy with an OMC 4.3L Cobra I/O engine with gear ratio of 1.68:1
With two passengers, and mimimal load, I get the following stats from the 14.8 x 17 aluminum Solas, 3 blade propeller:
wide open throttle (trimmed up): 4500 RPMs at 41 mph
3000 RPMs (trimmed down): 26 mph
coming off plane at about 21-22 mph
With a couple more passengers on board it is really slow out of the hole and doesn't hold plane well at lower speeds. I want to increase the performance to get better hole shot and handling at lower speeds. I am willing to sacrifice a couple of mph at the top end. I am an avid slalom waterskiier.
The helpful advice I received previously was to try a 4 blade 15 or 16 inch pitch prop, (dropping 1 to 2 inches in pitch in order to compensate for the 4 blade)
I asked my mechanic to order a 16 inch 4 blade. My mechanic just called Solas, which recommended that I put on a 4 blade, 14.5 x 17 prop (aluminum). The thinking was that the drop in diameter to 14.5 (from 14.8 which I currently have on the 17 pitch 3 blade) should compensate so that my RPMs remain in the proper range (the proper range for my engine is 4200 to 4600) and therefore I need not drop all the way to a 15 pitch.
The other possibility was to use a 14.8 x 15 inch, but I would prefer not to drop down that much in pitch so as to not lose that much top end speed.
Any thoughts?
Thanks.
Any thoughts?
Thanks.
