I`ve had my 15hp 2 stroke on several 15" transom boats over the years.The new Tracker riveted jon 1542 has a 16.5" transom.I measured from the top of the bracked on the motor,and it looks like I`ll still be at least 1" over the cavitation plate,I should be fine right?Seems like I might be a tad better in shallow water,if anything.This boat comes with a gravity wet well in the center seat,seems this could cause issues mounting a swivel base right where the door is,and thoughts on how the front seat could be mounted?I`d planned on mounting the stainless base deal with the nylon bushing hole.I might offset it way to the side,but would cause balance issius with my over 200# son.
