jakeyman_i_am
- Joined
- Mar 28, 2010
- 8
Hello,
New to the forums - I purchased a 15 foot Toma fiberglass boat with a Montgomery Ward 15 on the back of it.. The previous owner said the motor runs great, and he is right except for one rather major issue - It seems to overheat when it is running full speed... It will idle and run slowly in gear forever, but when you open it up, it will run for about a minute before it starts steaming and soon it will bog like it is running out of gas (overheating?) and die.. It will start right back up 10 minutes later..
I first though it was choked for fuel so I tried a new line and a different tank.. No luck.. Checked the water pump and the impeller looks good, no obvious clogs in the water intake or tube running to the power head..
I'm wondering if maybe the fuel pump diaphram is worn, and causing the motor to go lean at hi speed, that would make it run hot wouldn't it?
Any ideas guys, I'm stumped! Thanks in advance and I hope to give back to the forums once I know what I am doing!
