150hp mercury black max
pppsmurf47
I took oil injection off idles rich do I need a hotter plug and what plug do you all recommend Thanks
The original oil injection system vary's the amount of oil from around 100:1 at idle to 50:1 at WOT. Going to premix makes it rich at idle like in the old days. So now you have a smoker just like in the old days.
I would keep the plugs as-is and only think about changing after some time. Going to a hotter plug may cause the motor issues at higher rpms
Other opinions may be along shortly
Chris1956
A lot of those motors were converted to premix. I have one and it runs perfect.
If your motor won't idle well, the carbs may need some attention.
pppsmurf47
I haven't had it on water since I removed oiler .On rabbit ears at idle it seemed rich smoked quite a bit but knew it would going to put in water and run awhile see what it does
QBhoy
I’d rather see her smoke than not. Well played to pre mix these things. I learned the hard way as a younger man. Not so often the pump it’s self fails. More the oil lines or fittings usually.
