150XR2 (1986) Warning Module
HuddlestonBass
When I first turn the key on I get the normal 2 or 3 beeps then when the engine is started I get the never ending beep beep beep & so on. It's not a solid beep indicating temp. Here is what I have done so far. I have bled the engine's oil tank, checked the tank sensor (0 ohms), bled the oil line going into the pump, removed the pump and made sure the shaft is turning (it is), checked the pulse from the magnetic pickup (it is pulsing)and still I have the on/off beep continiously.. Should I assume that the Warning Module is bad? Part number 41470A27? Or is there something else I should be checking? Oh yes, how much oil would one see coming from the upper hose coming out of the oil pump when everything is correct? I appreciate any comments you have on this problem.. Thanks.... :confused:
