150xr2 trim leaking down
My 86 xr2 trim just started leaken down the tilt and trim works great i just left the motor toter off and when i got up the next day it Had slowly leaked down how do i go about fixen this thanks
17rogue70
Re: 150xr2 trim leaking down
justin , check the bypass valve on the starboard sode of the engine to see if it maybe loosened up or maybe stripped out for some reason. i just had to replace mine and it is kind if pricey for a piece of plastic.
Mine is on nice and tight if that part is just bad will it cause this leak down? Do you have the part # by iney chance?
17rogue70
893929 merc part # also has 2 orings. do you have any oil leak in that area?. might be internally bypassing. i also had to change pump motors on mine but that didnt affect the leak down on mine. the valve assemlbly threads on mine was stripped
I dont see iney oil by the valve if its bleeding down internally how do you fix that?
17rogue70
internals are little more for someone more exper. sorry icant help there . knock on wood , i havent had to go that far yet. i hope it is something quick and easy as well as inexpensive. good luck . sorry i couldnt be of more help. where r u located? maybe someone close to you can help troubleshoot the system
Thankd alot for your help man iam ganna check into that valve realese first and iam in tallahassee fl
Faztbullet
A internally scored tilt ram or debris in impact valve on tilt ram will make one creep down.....
Faztbullet you lost me there how do i check these thingsthis first time ive ever worked on a tilt,trim unit sorry for so many questions
Faztbullet
Check the manual release first the you can check the cylinder. It will require a spanner wrench to remove end cap and you will need to remove pin that hold tilt ram in place.
Is this somthen that needs be fixed asap? Will it mess iney thing els up its a slow leak
