Hi all,
I have a 1976 15' Steury tri-hull with a 1976 50hp mercury 500. With my buddy and I on it we were able to get on plane (400 lbs), though it minute to get there, but it planed. I added a deck to the front (3'x4' 3/4 inch plywood painted, sealed, and covered with exterior carpet - maybe 50-60 lbs). Took my wife and son out yesterday just for a lake cruise, maybe 500 lbs between the 3 of us. So basically I added 150 lbs, and the boat never got on plane. Engine runs smooth, idles, starts right up, ran at full throttle for an hour with no issues in terms of stumbling, bogging, missing - nothing, just would not get on plane. I adjusted the trim out one click (manually) to raise the bow a bit more, moved my weight to the back, tried everything but it just would not go on plane.
This is my first fiberglass boat, my 14' aluminum will plane my buddy and I with an 18hp merc, but the boat itself only weighs like 150 lbs.
So, before I start tearing into things - ripping up the deck to see if there is water logged foam, trying to increase motor rpm, link and sync, etc. I wanted to ask the question - should a 50hp on an 800 lb boat be enough motor to be able to plane out 5-600 lbs of people and gear or am I asking too much from this motor and I should be happy with what I got? I used to ski behind my buddies 16' hydrodyne v-hull with a 65 hp merc, and it never had an issue getting on plane, so that is my reference.
I read about weighing the boat, but I have no idea what the old trailer - solid steel, walking decks, etc weighs i am guessing a bit.
Thanks
Dave
Second question, for anyone that has one of these motors, I have found a few things the PO had tinkered with, one being electrical wiring, which I appear to have figured out - all but the tach is working now - tach works fine between 0 and 1500 but wont go any higher (engine RPM does, just the tach does not). I have attached a pic of the port side linkages at WOT (engine not running) I had to fix a couple things here (nut missing, idle speed screw not touching with throttle in neutral - idle screw looks 'different" to me - should it be longer - it barely makes contact when fully screwed in?). If you have one of these motors can you take a pic and send to me or look at my pic and see if anything looks out of sorts please?
Thanks again
d
Thanks
Dave
Thanks again
d
