15hp 1986 johnson
steveg05
running new wire from battery(4' long) what size wire to use
also what is the charging amps this motor puts out
thanks
steve
tashasdaddy
Re: 15hp 1986 johnson
same size as existing. i think it is a 4. some don't charge, and the ones that do only charge enough to maintain the battery. if you are planning on using the same battery for a trolling motor. plan on charging it after each use.
