15hp evinrude 2 stroke from the 80s no spark
Craigmail361
Where do I even start on this project? Got it from a friend and it's been sitting for years, no spark from either cylinder. What resistance readings should I be getting from what? Popped the flywheel off and it doesn't have points like I thought, just like a "pick-up" style coil and another bigger black coil at opposite ends of each other. Need help on the start of my diagnosis, all grounds and connections are clean and free of corrosion btw!
This is the weird magneto set up under the fly wheel:
https://www.ebay.com/i/232559780127...3D711-117182-37290-0%26rvr_id%3D1375300356513
That " wierd " set-up was very, very good and reliable !!------Both coils did not fail.-----That leaves the switch box / powerpack.-----On those 9 times out of 10 a new one restores spark on both.------But check the overall condition of the motor before spending your money.----Maybe it sat for a reason !
Craigmail361
Can u send me links on those, not sure why is meant by powerpack bad switch box, I remember them as a magneto and cdi! Haha
