Model # 15904E
I am replacing the impeller on my old 15hp Evinrude. I have lowered the lower end and noticed 2 things. The shift rod has a bend on the lower inch or so where it goes into the connector, is this normal? (I have only used the motor once and it did seem to shift F-N-R okay) and then secondly, should there be any water in the empty chambers that you see when you drop the lower end? I have water in the front chamber where the shift rod connector is. The chamber on the other side of the water pump (prop side) is dry.
