I just started working on a 15hp fastwin, I replaced the coils cause they were shot and a new impeller. I then went to get I started. I starts and ildes fine but then when I throtle it up in neutral it starts to pop and even sounds like it knocks a bit then it stalls out. That's the first propblem. The second problem I saw was that there was a little water coming out of the plate were the shift linkage is located. I popped it open and sure enough there was a coat of water everywere in there. What do I do next? Is it stalling because of a carb issue or ignition issue or a timing issue? Is there a seal I need to replace in the lower unit or is it ok to water in there? There seems to be plenty of water coming out of the pee hole. Thanks for the help.
