I have an '01 15hp 4 stroke Nissan that idles fine but it misses when I start getting under load. Once I make it to WOT, it starts to improve and eventually runs fine at high RPM/ It starts missing again as I drop RPM to slow. I have replaced the carb with a new OEM carb. I replaced the fuel filter and fuel line fitting on the tank side (o-ring was worn). I am running fresh marine grade fuel from a clean tank. I have replaced the sparks. Any ideas?
