Hi All!
I recently purchased an aluminum boat and 1980 Seaking 15HP by Chrysler. Boat and motor look like they had hardly been used but had been sitting a couple years after prior owner couldn't get it to start. Came with a bad tank of gas but motor had good compression & spark and would fire on carb cleaner. (I know... don't ever use carb cleaner. It's what was available at the time).
I brought it home, rebuilt the fuel pump, cleaned carb, replaced fuel lines and impeller, cleaned plugs. Cleaned tank and added new 50:1 mix.
After tearing the carb down twice more I still can't get it to start (unless I spray fuel in carb). Fuel pressure from pump is great. (shot fuel all over my wifes laundry.. yep I'm in the dog house...) Float, needle and seat all seem good. Gas fills the carb bowl but doesn't get to motor. No fuel puking out float vent which was problem prior owner had. After pulling the starter rope 30+ times the plugs are dry and show no sign of any fuel/oil mixture.
This is my first time working on an outboard but I'm generally good at fixing (or jurry rigging) things.
I didn't remove the press fit carb plug to clean the 4 small holes in top of carb body. Could this be the issue? I really want to test this thing tomorrow and can't buy a carb kit locally.
Please help. Fish are hungry and it's time to wet a hook.
Any Suggestions ???
Any Suggestions ???
