Think the water pump is out. The tell tale pee hole is clear (blew air thru it) but I am not getting any water.<br /><br />Replacing the pump should not be hard, but I have a question about the shift linkage. Where do I disconnect it? On my 150 it is under the carbs. I can't get under the carb on this thing.<br /><br />Thought I read somewhere it is down inside where you split the lower unit. <br /><br />Need a little help here please!!!!!
<br /><br />Thanks, ranger
