15hp wont stay running
teelaw64
I bought 1980 jhonson 15hp it ran when I bought it yesterday I change plugs and lower unit lube now it runs for few seconds gap at 30 it sat for few years it came with brand new tank and gas line and some gas 1-2 gal then I tried my tank still wont run
raczekp1
Re: 15hp wont stay running
1.clean the carb
2,check if fuel lines are not cracked
3.check spark
4.try compresion test
64osby
New tanks quite often have a lot of junk in them. Sounds like some was sucked up and the carb is plugged up.
Spray some premix in the carb and see if it fires. If it does clean the carb. Also double check the fuel pump.
