Re: 15r74
OK Jim, here's a guess.....you're carbs float needle isn't sealing. Pumping the primer bulb forces fuel through carb, excess fuel is being blown out the exhaust. Another possibility, blown fuel pump diaphragm allowing fuel to flood one cylinder with the same result.
