16 gallon aluminum fuel tank is leaking.
zalmaflash
My tank has developed a corrosion leak (thanks to ethanol) and a friend had repaired his motorcycle tank with "POR 15" which is an epoxy coating for the inside of the tank. $77.00 for the kit. New tank - $250.00 +.
Have any of you ever used this product or any other one like it?
Any advice would be greatly appreciated.
Re: 16 gallon aluminum fuel tank is leaking.
Ayuh,... Don't even Think 'bout it, in a Boat....
Yer Bud's motorcycle tank will leak onto the road, 'n 'is crotch...
A Boat tank leak becomes a BOMB, just waitin' to Explode...
Replace yer tank,... personally, I like Plastic....
zalmaflash
My tank is out in the open air, with air space all around including the bottom and I appreciate what it would be like if it was in the bilge. It is on a pontoon boat.
Just want to know if anyone ever used it.
