1662 prop pitch?
Capt. Steelhead
Hi Everybody, Can someone help me id this propeller it has 1662 on it seller says it came off 1985 125 HP Force what pitch is it and will it fit on 1989 125HP? it has 15 spline same as my '89. Thanks, Paul
steelespike
Re: 1662 prop pitch?
If your 89 is a thru hub exhaust sometimes called a "dual exhaust" and the 85 prop is a thru hub it should fit.
If the 89 is a Non thru hub ; I believe both a non thru hub or a thru hub will work.
jerryjerry05
No other numbers on the prop?
Place them side by side and compare the angle of the blades.
If they look the same then use the good one.
If your prop is say a 17p and you put on a 19 or 21 your gas mileage will go to crap.
