Hi all,
I'm wondering if there are any tips relating to my re-build of my floor.
It's kindda odd as there are no wood stringers (vertical -length of boat) as it is heavy guage wire mesh with a high density fiberglass covering. There are 2x4 wood stringers running across (horizontal) about a foot above the bottom hull that attach to the underside of plywood that are on each side of the gun wale (hopefully the trench in the middle of the boat is called a gunwale?)
The foam is dry and I remove a section to check, however all the wood half way down and to the engine is rotten and wet. I have carefully removed all of it. See pictures.
I have cut the floor out about 1 inch away from the sides of the boat. I am planning on cleaning about 4" up the side of the hull and fiberglassing in the floor.
Does this sound reasonable? I'm worried about how to "tab" to those two metal stringers. Any suggestions?
Any advise?
Thanks.
Any advise?
Thanks.
