175hp merc v-6 2 stroke oil inj
Hello, I have winterized many I/O's but can't locate any block drains on this v-6,I have already installed 5 gallons of Anti -freeze in the block but want to make sure all water is out.this engine is a sugar sand jet boat with this merc 175 oil injected 2 stroke.Steve
JustJason
Re: 175hp mercruiser v-6 2 stroke oil inj
Welcome to Iboats 123landrover.
In the future, post questions about your engine in the mercury/mariner section as your powerhead is the same as an outboard powerhead.
Thank being said. Outboard powerheads are self draining and do not retain water. I don't know how you put 5 gallons of antifreeze in the block but it has all run out on the ground by now.
Also, make sure you jack the front of the boat up real high to drain the mufflers/waterboxes.
Re: 175hp merc v-6 2 stroke oil inj
Jason,thank you for your speedy reply.I was going to post on outboard section but thought against it due to I/O config. Steve
JustJason
Nothing I/O about it.... Its an oversized jetski with an outboard powerehad :)
