18' lone star abandoned on property i purchased
the bogart
hey everyone i think i'm gonna take it on !!!!!<br />60's modle 18' alumnium cabin cruser. the deck and interior side walls look like they had been done with standard plywood and are gone. captain chairs look like bar like chaits that had been drilled and toggle bolted to the floor. gonna take some pics tomorow and post. anyway the plug hole (witch is in the bottom not the back) was pluged with trash and i let the 400 gallons of water or so out today. it's a riveted boat and i seen no water on the outside of the hull so i'm hopefull. anything i need to look for ?? ohhh yeah checked transom..... solid as a rock. not sure about the motor yet 80hp evenrude late 60's eirly 70's i think electric shift. also the cabin has a plexi-glass windshield in bad shape any ideas??
CTD
Re: 18' lone star abandoned on property i purchased
I would check on getting it registered before you put any money into it. Then check around the seams for corosion. Then have at it.
SeaMasterZ@aol.com
lets see some pictures!!!<br /><br />Im looking for a 21- 24 footer lone star cabin or starcraft chieftain, I love the idea of a BIG hull thats lightwieght, powerable by minimal power ... the twins or the 125 would power it at a hell of a clip - comparable to a fiberglass running those 200 plus horse monsters
pinerider
Ray, there's one on ebay (from New Orleans) right now for $1500 at: <br /> ebay
D
DJ
Guest
That waterline on that boat is a bit scary. Look how low it sits in the stern!
Hooty
Hey djohns,<br />If you're talking about the boat on ebay, look at how much set-back it has. Cruiseliners didn't have inplace foam so it ain't waterlogged. It's probably a pretty good ole boat for tha price. Those are original decals too.<br /><br />c/6<br />Hooty
D
DJ
Guest
Hooty,<br /><br />If it were mine, I would be doing some serious weight redistribution.
They Didn't Make Motors that Big in 1955......<br /><br />A Foam Block, Glassed + Fitted Under that setback would make that a 23' Boat....<br />I bet that would make it Handle Better, + Set Higher.....
Hooty
In later models, they did away with that setback and mounted the engine(s) on the transom. By the way, that's a 21' not 18'.<br /><br />c/6<br />Hooty
SeaMasterZ@aol.com
Bottom needs some work and has a leak on the right side caused from hitting something.<br /><br />there is your waterlogging, lol, damm thing was perpetually sinking!<br /><br />motors were BIGGER then, they just didnt have any output, lol<br /><br />ever try to lift a late fifties sixty horse Starflite? youll see stars, hence the name!<br /><br />gotta love Ebay, vehicle condition GOOD except for that sinks like a stone thing!<br /><br /> :D :D :D :D :D :D
