1860 g3 50 hp 4 stroke what size prop should be used
tntcoops
I have an 2010 1860 g3 sc 50 hp yamaha with a 10X15 prop. It will not come up to plane very fast . It will run around 27mph but as i said the hole shot is terriable . Does anyone have this set up if so what size prop are you running . thanks in advance for the help.
mommicked
Re: 1860 g3 50 hp 4 stroke what size prop should be used
Welcome aboard! I have an 03 1860sc w a 03 Yamaha 4 stroke F90 and I love this boat. My motor weighs 370 lbs. It obviously is different in performance than yours. I had issues w steering at high and low speeds and porposing and prop slip or blowing? out w the factory alum. 3 blade 13.25x17" pitch prop. I learned a great deal about props here at Iboats, Thanks everyone, and bought a Solas 4 blade alum. prop w 17" pitch last year. It made a HUGE difference in my boats performance. It almost jumps on plane at holeshot, steers/handles like a sportscar, and stays on plane at lower speeds now. I will not go back to a 3 blade on my boat/motor. When I bought the boat the engine was mounted all the way down on the transome and the cavitation plate was below the hull 1.5" +/-, I have moved it to the next mounting hole and it improved porposing a little, the top of the C-plate is still slightly below the hull when trimed to parallel w the keel. I may try to raise it higher soon as I believe these boats are extra sensitive to cavitation plate position. Solas props are cheap and you can get them here at Iboats marine store. I think a 15" would work well or 13" if you carry alot of weight. You need to check your RPMs at WOT to get the best pitch for your setup so the engine is in the correct range and not dogging or overreving. I assume G3 recommends the 15" pitch on the 50hp. I have found my boat is over RPMs w the 17" on the F90 about 500rpms at WOT.
steelespike
Just reading your figures it doesn't add up Calculating for your rpm it comes up at about 3,900. But this seems to be exceptionaly low.Is your speed by GPS? do you have rpm figures?
I also feel your speed indication is low.if its gps that will help stabilize the calculation.
I feel the speed is probably 8 to 10 mph slow.
Check the motor height antivent plate should be about 1" above the bottom.
Be sure your throttle opens all the way don't assume its right because of relatively new install.Does the boat respond to up trim?Do you trim down for hole shot?
tntcoops
I checked the speed with GPS. I do not have a tach on the motor. The plate is around 1/2 inch above the bottom and if you trim it up very much it will start blowing, prop slip.
I have called three G3 dealers and they have all said this is the correct prop but I emailed G3 and they said it took a 10 5/8 X 12 . So I am not sure what to do??? Thanks
steelespike
You need to get your self a tach; either permanent or temporary. Tinytach or optical tach.
We can't trust my figures for one thing I guessed a 10% slip yours could be anywhere.
You need the tach to figure what change is in order and to tell if the new prop works.
Your info and my figures indicate something is not right.
mommicked
Yamaha's outboard website's preformance bulletin for the G3 1860 cc w F50 shows 11 5/8X 11pitch, 30mph @ 5950. Check it out. Oh, it also says 3.74 sec. to plane.
jimmbo
When I first saw 1860 50hp, I thought WOW, there's an antique! Finding parts including props isn't gonna be easy.
steelespike
It does appear an 11 would be perfect with the rpm at 5950 for all around performance.
If you run light most of the time you could try a 13 it would put you at about 5550 and around 33 mph.
