Re: 188 vs 5.0L volvo
You could pretty easily drop in a 351 as well without needing a new bellhousing, exhaust, etc. The 351 would get you the hp you want and with its extra umph, may get you close to the fuel economy. The big problem, to me, in converting to a GM block is that you will have to move the motor mountig points. On my boat, that would be a nightmare where the mount studs are embedded in the stringers. The actual connection to the outdrive would be interesting, but since mercruiser primarily used GM engines, the parts are readily available. My rough guess for drive parts would be bellhousing, motor mounts, and maybe a Y pipe? If you could find a donor boat, that would make it easier.<br /><br />Have you considered a new dfi or 4stroke outboard on a bracket? That might get you where you want, but would make for a fun time of filling the transom.<br /><br />I just saw a price on that 5.0 somewhere on the net (before shipping) of almost $7,000 for the engine alone, or just over $10,000 with an SX drive. That doesn't include the labor to install either. A couple thou in a 351 might not be a bad option, you just might need to re-prop. <br /><br />During the 90's, OMC produced a fuel injectes 302/5.0 Ford that was rated at 245 hp I believe. If you had your 302 built up a bit (or 351) and added a Holley pro-jection kit (I think they run under $1000?), you may get what you want for somewhere in the $2-4k range depending on if you do the work or not, without the headaches of trying to put a GM block engine in there and dealing with the controlls needed for the newer engine.<br /><br />Another thought, is there anywhere else on the boat where you could put an additional tank? My boat has two tanks connected through a valve. Each 18gal tank is in the base of the lounge seats.<br /><br />The 188hp 302 Merc build is an interesting beast. I think the pistons were chosen more to keep the compression Ratio down and combat poor fuel more than anything. The few mods I did to mine when I went through it really woke it up. I would love the fuel injection, but budget has me slowly collecting the items i need to go to a 4bbl carb.
