This engine has been challenging.
Top speed according to my GPS is 9mph, used to be 7.3mph.
What I've done so far.
new points, coils, condensers, plugs, plug wire, rebuilt the carb, bought a used carb on e-bay, rebuilt it. Compression 105/95, spark from both plugs, pull one plug and the engine rpm's change, pull the other and teh same thing happens. there both firing. I aslo machined a new cam follower from bronze. The old follower had grooves worn into the rubber.
The ebay carb increased my mph from 7.3 to 9.
Question- the flywheel appears to have only one coil, the other side appears to be for balance purposes only. reason I say that, is only one side of the flywheel is megnetic. Should both sides be magnetic?
What else can I check?
What am I missing?
What am I missing?
