structural1
- Joined
- Aug 2, 2012
- 34
Hi guys... almost have the 19' regal cuddy back on the water. Engine is the dreaded Merc 3.7 and it has an enclosed doghouse engine cover. Quick question. When I bought the bought the routing for the 4" bilge blower hoses seems really odd. I think it may be routed wrong. There are (2) "vents" on the topside stern above the transom that are orignal to the boat. They vent to the outside of the boat and are about 18" apart but are enclosed under a clear plexiglass cover. The clear plexiglass cover is open to the outside air on the bottom side. Since the vents are so close and sort of in an enclosed area under the clear plexiglass cover it seems like they would pull/vent from the same air.
Running into bilge are 2 4' hoses. One hose has an inline blower and terminates on the port side of the bilge. The other hose is continous and terminates on the starboard side of the bilge. Oddly enough the blower is wired to blow INTo the bilge and not suck air out.
So here are my questions..... The Bilge blower should suck air out of the bilge and blow air into it correct? Also.... wouldn't the in and out air mix together sinec the vents are so close and under that plexiglas cover?
Thanks for any help.....
