Hi all,
I am new to the site and am hoping to get some advice on my '48 Scott Atwater. I picked it up in the fall and it ran great in the barrel at high speed and idle for as long as I wanted. Now I just pulled it out to test before a trip to the lake in a couple weeks, and it fires right up on the first or second pull with the choke pressed, but it coughs and dies within a couple seconds. It will do this over and over again as long as keep restarting it. I can actually get it warmed up by repeating the process many times. I pulled the carb apart and soaked it for a few days, and then I poked a wire into all of the ports that I could see. It was very clean to begin with though. I adjusted the high and low speed carb valves all over the spectrum and I can't get it to stay running. It has a new plug and pumps water great. I don't know what could have happened over the winter to cause the problem. Thanks in advance for any tips!
