Re: 1953 Evinrude 7 1/2 HP Sportwin
The 7512 was the neutral clutch version of the Fleetwin, and the last year they used that shifting method. Your magneto is all standard OMC coils, points and condensers should you need mag parts. Your impeller is similar to the readily available impellers for later 5.5/6/7.5hp models, but needs to be trimmed down on a belt sander. The deck height is shorter on yours. The neutral clutches often need a little tinkering to work right, but aren't too hard to work on. I've got the same model and ran it just last weekend. Good little motors...<br />- Scott
