1953 Sea king 5hp (5S10) Water tube not going into upper hole.
Livebait68
I'm replacing the water pump...easy...but I can't get the copper water tube to align with the hole in the upper part of the unit (I cant see it and it seems that I have to move it what I can till it slips in?) Does anyone know of any 'tricks' to get this tube to seat into the hole correctly? BTW....I have a hard to fin manual for these motors that I'd be happy to share. Thanks in advance for any insight.
F_R
Just so others will know, it was not necessary to remove the lower unit "foot" to replace the water pump. I don't know if I ever took one apart there or not. But if I did, I don't remember any "trick".
EDIT: Perhaps the trick is to put the tube in the upper hole first, then the lower hole as you install the foot?
