New to the list. I can't seem to determine how to properly split lower gear case from the upper case to check on the cooling water impeller as I'm not getting any return water from the outlet and the inlet is not clogged. I've removed the 4 bolts holding the two cases together and that loosens things up a bit but it seems that the shift linkage needs to be disconnected to get the two pieces apart. Anyone have any Ideas? Thanks
