I have a 1960 elgin 25hp electric start that i recently acquired. the engine is getting fire and fuel. if i hold the choke closed and give it a little throttle it will start right up but runs rough and will die after 10 seconds or so.if you remove the plugs they are soaked in gas. the fuel pump is new and the carb is clean. there is not much resources out there for these motors. i need some outside opinions and knowledge to help me out here. thanks!
