I have a 12 foot basstracker tadpole with a 1960 sportwin 10 hp on it. It will not plane the boat with 200 lbs in it. I cleaned the carb and put new plugs in it. After investigating i found out the butterfly valv in the carb is not openind fully. i looked at the linkage and found no way to adjust it. the linkage is connected on the shaft with a screw but the shafts are cut with a flat spot on them so the linkage will not slip.I have adjusted the mixture needles and have had no luck.Should this motor be able to plane this boat?<br />Please help..
