hello, I received 1961 15hp viking 15d12v (same as the Gale from what I've read) from my Dad. About 10 years ago he got it from my Grandpa. According to my Dad my Grandpa only used it maybe a dozen times before it got put in a shed for who knows how long. When my Dad got it, he got it running but it wouldn't run very well it would die when you throttled it up. So it ended up get put back in a shed until some one had time to try to fix it. Anyway I have it now and would like to get it going. The Engine is very clean inside. I took the carb off and it was clean. However fuel pump diaphragms seem dry to me so i'm guessing this was the problem 10 years ago and still is today. That water pump looks OK but the impeller has 1 broken off fin. OK so basically why I decided to post was I am not sure where to find these parts I read evinrude and Johnson have compatible part but I'm just not sure which ones are. I also want to see if people that know more then me about these things think it's worth trying to get it going. Also is there more parts I should replace now? sorry this is long winded.
Parts I know I need.
-Fuel pump diaphragm
-Impeller
-Spark plugs.
Thanks for advise.
-Impeller
-Spark plugs.
Thanks for advise.
