1962 Mercury kiekhaefer 450 45 hp telltale
62Seaglass
Hello, I just recently acquired this engine on my antique boat. I did a test tank run and was wondering if there is supposed to be a telltale coming from the engine area…… There is definitely water coming from the exhaust port, but I thought there was also supposed to be another telltale.
merc850
There should be a hole in the lower cowl pan on the port side, you have to get down and look up to see it; it could be clogged with debris. I would replace the impeller just to be safe.
You must install a new water pump impeller first.------This motor does not have an overheat horn or a shut down system.----It would run till it is too late.----Have one just like it in the back of my truck.----Tried to sell it at last swap meet but no takers.
62Seaglass
That’s a bit scary. I did order a couple of impellers and will install a new one
merc850
You should also check the point gap in the magneto and the cam wick is important too.
Grease the top of the driveshaft and the propeller shaft and any bolts that hold the waterpump together, I use Anti-corrosion from Mercury.
Agreed.----Just 4 bolts ( 3/8" wrench ) to split the magneto.---Clean and set the breaker points------Careful work required as the bits may be a bit spendy if you damage plastic parts.----You can test spark output before putting magneto back in place.-----Magneto shaft only fits one way so no need to worry about timing.-----A new magneto drive belt should be considered.----Belts were all the same from early 1950's to late 1970's.----Most Mercury dealers will have it in stock.
merc850
Tell tale water is from the exhaust cooling manifold there are no hoses; shove a piece of wire in it to clean it out.
62Seaglass
Does not seem to be any obstructions EBB94EA0-80C7-47D6-BCAA-ABF03DBCD1F0.jpegEBB94EA0-80C7-47D6-BCAA-ABF03DBCD1F0.jpeg992E2E9D-2FDC-46AD-8529-B086FA80589C.jpeg
merc850
It's on the underside of the cowling you are looking at the inside you can't see it from there.
???----Where are you looking for the tell tale passage way ??-----The hole shown in the lower cowling is not the tell tale !!
62Seaglass
Here are some under side pictures
???-----Those are drain holes should there be a leak in the cowling.----Either from rain or a gasket leak.----Drive by your local shop and ask them to show where a tell tale would be.
62Seaglass
Can do……first outboard…..I clearly don’t understand this units telltale
