1963 Johnson 40 HP manual shift and 33 Johnson gear case
grumpyguy
Question for the knowledgeable here...
Will the gear case for a 33 HP Johnson fit for a 1963 Johnson 40 HP? I had thought it would as I see lists the same part number for each, however I have been told the 33HP has no thermostat so they are not compatible
Thanks in advance!
I think the bolt pattern is different too.-----Looking for a lower unit ?----Posting your location may help.----Where do you see the same part # ???
Yah-----They look the same to the untrained.----But they are not the same.-----Where do you see the same part # listed ????-----evinrudeparts.ca----Might be able to help you.
grumpyguy
Yah...untrained thats me....LOL
grumpyguy
I'm in Toronto...engine runs great but gearcase leaks and bolts holding lower half of gearcase onto upper half leak. Would be a shame to scrap this thing
grumpyguy
are there any other big twin engines for that era that would fit this? Having problems finding this part
grumpyguy
I sent them an email. Nice thing is that they are on the way to the cottage!
