I have a question that's been puzzling me since I dissambled the lower end gears.When I took off the gear housing cover there was 3 "washers" that came off with it.All most the same diameter as the cover. That seemed odd but I continued with the dissasembly.I took some pictures of the shaft, carrier,gears and the 3 "washers".Could someone look at the photos and see if I'm missing anything.The foward gear bearings, and I'm assuming that there should be a shim between the bearing and housing, are still in the housing.The clutch dog and spring are still on the prop shaft.I got a funny feeling that someone dissembled this and didn't put the shims back in there place.
