1965 Evinrude will not shift forward
jbeck
I have a 1965 Evinrude 18HP Fastwin electric start motor. The serial number is 18402D-F06132. When shifting into forward gear it will pop out into neutral. I adjusted the linkage but that did not help. Any ideas as to what the problem may be? Your help will be greatly appreciated.
steelespike
Re: 1965 Evinrude will not shift forward
Pretty sure you have a bad shift dog or clutch dog as some call it.<br /> That is the part that slides between the forward and reverse gear to engage them.<br /> Both the clutch and gear could be worn.<br /> It is a fairly straight forward repair with a <br />manual.
D
DJ
Guest
Steelspike nailed it. Bad clutch dog.<br /><br />You'll have to go into the lower unit to replace it.<br /><br />If you want to do it yourself, hail Joe Reeves on this board. He may have one or can advise you if this model year clutch dog can be turned around.
papasage
go down to the reply i put in on the 1961 lark 111<br /> you will find my answer to yo the probility of the cause of your motor .email me if you need any moe info.
papasage
not nesary the clutch dog baleve me had the same problem . not the clutch dog . not saying it isant but could not be . if it is or gears they can be re cut by a machine shop . have seen that don. mine had a loos shiftrod under the powerhead
