1967 Johnson 20hp not starting....tries when primed
stykler
Hey there...<br />I would appreciate any help that you guys could give. Recently bought a boat that had been stored for about 4 years. Motor is a 1967 Johnson outboard....20HP....model fd 21. Wanted to see if I could get it running quick before I put her away until next year. Tank is good, replaced fuel line and bulb. Pulled the spark plugs and made sure I had spark...i do. I crank and crank with not much response. If I take out the plugs and put some fuel mix in to prime, she comes to life briefly and then dies. I have not replaced plugs yet.....might do that. HELP!
Re: 1967 Johnson 20hp not starting....tries when primed
Sounds like the fuel system is all Cruded Up....
coupedeville
Fuel pump? Or like bond-o says, crap in the fuel system. You'd be surpised what gasoline turns into after a while! :eek: It sure don't look [or act] like gas anymore. :mad:
coupedeville
By the way, you might be better off in the outboard forum, this is the inboard side. ;) <br />Right church, wrong pew.
magster65
PEW is what it smells like in that gas tank I bet!<br /> :eek: <br /> :p
