Re: 1667 MFG Niagra
Re: 1667 MFG Niagra
Welcome aboard Orrin! That Niagra is a beauty!!
Some things to check out:
-Transom - with the motor locked in the up position push down on the lower unit to see if there is any flex to the transom. If so it may need a new one either soon or eventually. You can negotiate the price if it's rotten.
-Motor - If possible try to take it for a water test to make sure it runs and pumps water well. You can also test the other features of the boat at the same time.
_Paperwork - make sure the seller has the current registration. The sticker on the boat is current so it probably won't be a problem. The trailer looks much newer and should have a title.
Other than those points, that baby looks SWEEEET!!
I guess all the clean MFGs are in Oklahoma! Try to bargain, but if the motor runs and the transom is solid, I'd pay $1,500 for it. Keep us updated!
BOB
