1969 40hp Evinrude prop
rustyzipper
Greetings. I'm hoping somebody can help me with what propeller(s) should be on this outboard engine? The engine came with no manuals or a prop for that matter.
Engine model # 40953R.
steelespike
Re: 1969 40hp Evinrude prop
In 69 standard prop was 101/2 X 12 optional was 103/8 X 11 1/2, 10 3/8 X 13 1/4, and I believe 10 3/8 X 14.On aftermarket props diameter may vary.
The actual prop selection would depend on your particular application and activities.
rustyzipper
Re: 1969 40HP evinrude prop
Thank you steelespike.
The boat, a 15' Glassmaster, runabout.
The previous owner mentioned the craft
had issues planing out, taking a long time to do so.
Being a first time owner I'm not really
sure of correct prop, applications.
I was looking at the Piranha composite props.
As far as activities, just fishing for the most part.
jay_merrill
If your boat is the 15' Glassmaster trihull, you should be able to run a 13" pitch prop on it. I had one, which at one point, had a single 1958 ERude 35hp Bigtwin on it. I ran it for awhile at a light load with a 14" pitch wheel, which was a bit overpropped. Since the wheels for the Bigtwin & Seahorse 35hp motors were the same as for the 40hp Lark and Super Seahorse models, the comparison should be valid.
I just looked at the prop sales section here at iboats and you can purchase an 11-1/2 inch pitch wheel and a 12" pitch wheel. The 12" version comes in Michigan Wheel and Quicksilver brands, for $87.99 and $114.99, respectively. I bought 14" wheel in the Michigan Wheel brand as recently as 5 years ago, but it looks like the selection for these old pin drive props is diminishing rapidly.
Bear in mind, also, that you can have an aluminum wheel re-pitched. I believe that they can be pitched-up as much as an inch to an inch & 1/2. You might also try surfing the auction sites for a 13", 13-1/2" or 14" pitch wheel, depending on which one seems to be right for the boat.
steelespike
What year is your glassmaster.It appears the 15 weighs in at about 900.
It would seem to me the 40 would have a tough time planing it quickly.
Brochure says standard is 10 3/8 X 12.I would think this would be for the typical boat the 40 would be on.I think a 900lb boat would be near the top for that prop Especially if you add a couple of buddies and some gear.
I would start with the 12 and adjust from there.If the 12 comes up light you can allways throttle back a little if you end up over propped you just plain shouldn't run the motor over anything more than 1,500 or so rpm.
You shouldn't run without a tach.A Tiny Tach is reasonable ,easy to install and fits any similar motor without regard to stator poles.
