1969 Bahama Starcraft steering
Cosmos1
I'm trying to get my 1969 Bahama Starcraft sea-worthy and need to replace the steering cabling. What's my best option to do this?:confused:
Bighoss
Re: Cosmos1
Re: Cosmos1
Coated cable and pulley system? Can you post a pic? These guys will get you squared away.
ezmobee
Re: Cosmos1
Re: Cosmos1
Your best bet is to just replace the whole system. You can get a complete rotary set up from here http://www.lowcostboatingstore.com/...e-9-ft-to-20-ft-with-STEERING-WHEEL_p_19.html for $111 and it even comes with a new wheel. This assumes your motor has a tilt tube to attach the steering rod too. Most '70s or newer motors have them. Here's an example:
http://www.inkbox.net/whaler/parts/steering-arm.jpg
If you have an older motor that was using a cable and pulley system, it can be converted to use a modern single cable system by bolting one of these attachment points to your transom http://www.easternmarine.com/Teleflex-Clamp-Block-Kit-SA27055P/
tgp***
Re: 1969 Bahama Starcraft steering
I put cable pulley back on my 66 nassau, easy and inexpensive. Works great. I refinished my steering wheel too, with JB weld and Rustoleum Plastic primer and paint. it turned out great!
Here are some links to check out....
OBC Standards manual - online PDF this is actually kinda cool. Lot's of info....
http://www.boatsinthebelfry.com/1959-obc_manual.pdf
How to wind the drum
http://www.glen-l.com/supplies/06123.html
riggings
http://www.glen-l.com/weblettr/webletters-3/wl26-fig1.html
