1969 evinrude 33hp
Jw6933
I’d like to change the steering to a steering wheel not sure what I need or where to get it
Is there a single push / pull cable on your boat ?----Or is there a " tiller cable " system on your boat ?
Chris1956
It looks like the tiller arm is missing from the port side. Maybe an incomplete conversion to remote steering?
There are kits to install remote (steering wheel) steering. That is the easy part.
Does that motor have the vertical shift lever and clamp that will hold a shift cable? (likely on starboard side). Is there also a throttle lever (usually under port side bottom cowling), that can be pulled/pushed by a throttle lever?
