OK so I'm pretty new to boating. I have a 1970 Mirrocraft Titan 15 foot with a Mercury 500 Thunderbolt 50HP.
I have an SE Sports whale-tail which gives me mixed results. If I don't run it, my prop vents a LOT and slips in the water. If I run it, it runs better but I think it slows the boat down a little. One time I GPS tracked the boat and was right around 28~30mph without the tail, but I've never checked with the tail on there.
If I'm out fishing and I go from point A to B, I don't really need the tail but if I want to pull tubes, I do and if I take it off and turn the boat almost drags to a stop and gets REALLY slow.
Motor as mentioned is a 1970 Merc 500, 13 spline. I have had 3 props but I broke one in the river, took a blade clean off. Was a factory Merc prop, 10 1/4, 13 spline, 13 pitch. I'm not even sure if it's the right prop because the factory service manual says it should be 10 3/4 inches.
Anyway I have two backups made by Michigan Wheel here locally, both are 10 1/4, 13 spline, one is 12 and one is 13 pitch. I run the 13, I've never ran the 12, it's still new in the box. Never saw a point to run it, my understanding is that it's slower.
I want to get more speed so so I can whip some tubes around. I know people with similar boats that haul at like 40~45mph. My motor is good, compression tested last year on all 4 at right around 140~145 -+ 2~3psi depending the cylinder. Carbs were cleaned this past winter, seems to run good.
My friend told me he thought my prop was too low of a pitch. Asked me what my RPM range was. I do not have a tach though. I know I'm going to have to get one to get this boat setup properly. Going to order a one next week when I get paid.
However, what starting point should I be at with a prop? My friend has a 16 foot Starcraft that sorta looks like mine with a 50HP Johnson and he is running a 17 pitch and gets 40~45mph. I do know his boat is lighter than mine, I have one of those foam filled hauls with no stringers, he has no foam and stringers.
I went threw my factory motor manual and found this section. From what I'm looking at based on boat length, weight etc, I probably want to be at a 17 pitch maybe? I don't know, maybe I don't understand working boat loads etc. Do I ignore the speeds listed and solely rely on tach readings once I get one installed?
Also here is the boat I have:
