Re: 1970 5hp Wizard Carb Kit
the parts you are looking for you should be able to obtain from any small engine repair shop being you are looking for tecumseh parts.the carb rebuild kit for most snowblowers and lawn mowers is the same as your carb, the kit will contain float,needle,seat,bowl gasket,welch plugs. the pump element is part number630953 which can be cross referenced over to an oregon part i believe the valve cover gasket is 631554 and the flap valve is 631555 those parts are not as critical as the pump element unless they are damaged. the pump element needs to be put in at a 45 degree angle / or it will not work.you should read through a lot of the other posts in this section as many units were built by eska "sears,wizard,game fisher, sports fisher,ted williams,hiawatha, just to name a few. the more you research the more knowledge you will obtain on your unit. good luck.
