Motor: I have a 1970 Merc 75 (7.5hp) 2-stroke. Thunderbolt ignition.
Background: The motor has been in storage for approx. 2 years but was starting fine prior to storage. It has NOT idled well for quite a while. Just put in new spark plugs, have great spark. Fuel is also fresh, no issues with tank or line/bulb. Historically, this motor has been well maintained and winterized.
Issue: The motor will only start at 3/4 or higher throttle, which requires starting in FORWARD (in NEUTRAL, you can only adjust up about 1/4 throttle), and once started, stalls as soon as you reduce throttle below about 1/4. (I am aware you can remove a bolt to start in NEUTRAL at higher throttle, but that won't solve the underlying problem here).
I'm looking for help on where to start. I assume most will advise removing and cleaning the carb first, which I can do. I'm not familiar with this ignition and am hoping that's not in the mix at this point.
