1970 Sears 5hp 217/5861 Clutch rebuild?
M
mrcrabs
Guest
Re: 1970 Sears 5hp 217/5861 Clutch rebuild?
your lucky it broke in gear and most do, if you go shopping for a replacment be sure to measure what you have...they came in sevral lengths
Nitram4891
Thanks. I've half looked for a replacement but probably won't bother. I was hoping there was a way to take this thing apart?
M
mrcrabs
Guest
nope, there pressed together...you can find a used one or I can look around for you if you need some help, expect to pay as much a $50
Nitram4891
Thanks for the help, I think I'll stick to the direct drive for now. When in neutral, can you spin the prop freely when these are properly working?
M
mrcrabs
Guest
yep you can spin it, to much nuetral idling and rust is what kills them, as you have found out they lock directly when in gear, and spin internally when in nuetral
Nitram4891
Thank you very much, this has been extremely helpful I'll measure it up before I put it back in and lookout for a spare in the future.
