AndrewsForces
- Joined
- Jun 15, 2014
- 10
At my cottage my neighbours asked me to see if I could fix there 5hp evinrude for them. I don't know the year of it but its from the 70's or 80's. The engine is hasn't run in two years they said they took it to the marina on our lake and they got it running and when they left it for the winter it never ran again. I don't know a thing about evinrude engines (I have only worked on Forces) but I would like to help them. I think I will replace the fuel lines, add fuel filter, replace spark plugs, clean spark plug heads, check fuel pump rubber, and clean carb. My question is sense know nothing about these engines is what else should be looked at / replaced and if you have any tips. Also what spark plugs should the engine be running on so I can buy the right ones. Thanks!
