1970's Johnson Sea horse Idle Question
Rubixone
so this is a 1970's sea horse, its a 6hp, and It runs great works fine and all but the idle is just a little off. I work on boats for a side job but I have run into this situation before and been a little baffled. So what happens is that i have to turn the tiller arm throttle up a little to keep it running, for starting it has to be throttled just past start, to shift it has to be just past the shift marker and it wont go in to slow it just kills. Its a carb issue but not a carb cleaning issue, what happens is if you hold the inside flap open just a hair(manually throttle it up), all throttle positions on the tiller arm work properly as in the timing advances properly under the fly wheel... So the ultimate question is how do I keep the throttle up with out an adjustment screw??? Mind you these motors do not have a roller(they just have a little plastic piece that sticks up, some get grooved and worn but this one is good) and they also do not have a throttle adjustment screw to advance the throttle. oh and it is not the low speed needle adjustment either...
In the first pic you can see where slow naturally sits, and in the second pic you can see where I have to hold the throttle out to in order to keep it running in the slow position on the arm...
Rubixone
Re: 1970's Johnson Sea horse Idle Question
any input would be helpful
AlTn
never fooled with one with exactly this set up ,but there should be a couple of screws on the underside of the timing cam allowing it to be moved in or out...with the throttle in the start position, the flat portion of the follower should rest on the cam so that the throttle plate is just beginning to open..sometimes with the roller type follower it helps to have the center just beyond the mark...then, with the engine in gear...at wot the throttle plate should be horizontal in the carb throat < not over rotated >
Rubixone
thank you for the feed back, I looked at the CAM throttle control and it is adjusted all the way out, and cannot be adjusted any more in my favor, its almost as if the little metal band that says "stop slow start fast" is moved clockwise on the arm, however it isn't.
Rubixone
No that plate is called the CAM throttle control and it is just fine, but those links are pretty cool. so thank you for the input....
AlTn
is the cam follower link installed with the straight portion pointing towards or away from the carb?
