1970's Ted Williams 7.5 hp out board motor
Status
Not open for further replies.
Batman89
I have a seven and a half hp when it starts it'll run f when it starts it'll run for a little bit and then it just dies like its flooded and gas leaks out the exhaust does anyone know where to get a rebuilt carburetor or parts to rebuild a carburetor
freeisforme
Re: 1970's Ted Williams 7.5 hp out board motor
I got a needle and seat and bowl gasket for mine at the local hardware store, its the same as most Tecumseh powered lawn mowers. Most that I've seen mainly need the needle seat replaced with one that can tolerate ethanol.
MahtyMaht
Duckbill.jpgDuckbill.jpgYou gotta post a model number. Then you can go here to get part numbers;
http://www.searspartsdirect.com/partsdirect/index.action
Then you can get OEM parts either here;
or here;
Results for ESKA - Sears / Ted Wms
You most likely have a split or torn fuel pump element, aka duckbill - It's an orange rubber part that's set in the face of the moounting flange of the carburetor. Sorry about the double dip. Be sure you put the new dickbill in at the 45 degree angle shown, or you'll be doing it twice.
Batman89
I went to the sears web sit and they are saying the numners come back nothing it was running. I ran a full tank out filled it back up and now this i can get it to start but it runs hi rpm for a min then dies
MahtyMaht
Fuel starvation does that. Is your fuel pump element OK? clean that carb in detail, man. You know you got spark and compression, the only thing left is fuel delivery.
dscsr
I have a 70s ted Williams motor but have a few questions before I try to start it. first, the model # is 217-5949-0 and the serial # is 199174. is this a 1974 motor? if not, what year? second, what is the correct fuel mixture? and last, is this an air cooled engine? thanks for your help.
brim_buster
its a 1973 mix is 32:1 and it is air cooled powerhead but has a water pump in the exhaust leg to keep it cool.
Eska7.5hp
I have an eska 7.5
I keep blowing the diaphragm fuel pump.
Im wondering why this keeps happening
the carburator is spotless
I positioned the fuel pump in a 2 oclock position
Status
